fix rusting
Old Jan 24, 2008 | 09:23 PM
xxSCRAPPYxx's Avatar
Default fix rusting
i have a cab corner rusting on my 00' xtreme. i was wondering how u cut it out and fix the rusted place. any one have any tips or instructions??
thanks
Old Jan 24, 2008 | 09:41 PM
Boosted 99 TA's Avatar
you can buy cab corners just order em, once you get them you will see wher eyou have to cut and weld.
Old Jan 25, 2008 | 06:25 AM
Fast_94_Z's Avatar
order the cab coner, measure it mark where you have to cut but make it a little smaller then the cab corner itself just in case because you can alway go make and cut more, make your lines, cut out with a cut off wheel, grind down the edges of the cab corner and where you cut out so you have a good surface to weld to, tack it in, if everythings good then weld away, grind down the weld put some 1k primer on there paint or undercoat or whatever you decide.
