stripped threads
Old Feb 2, 2008 | 01:21 PM
pwterz28's Avatar
Default stripped threads
i got a used oem ss hood and one of the bolt holes that holds the bracket for the strut mount is a little stripped out what is the best way to fix this thanks
Old Feb 2, 2008 | 01:28 PM
vetman1's Avatar
Re-tap it. May have to re -thread (die) the bolt as well if it has been cross threaded.
Old Feb 2, 2008 | 01:33 PM
boostfan's Avatar
if that does not work, you may want to try a helicoil if there is enough meat left. If that does not work, you will probably need a rivnut
Old Feb 2, 2008 | 01:40 PM
pwterz28's Avatar
thank guys what is a rivnut
Old Feb 2, 2008 | 01:44 PM
vetman1's Avatar
A nut that installs like a rivet. It take as special gun like a rivet gun. As you pull the trigger it squashes the nut on the backside like a rivet and that is what keeps it in place.
