Fender Tabs
Old Mar 9, 2008 | 10:23 PM
lincolnmkv's Avatar
Default Fender Tabs
What direction are the fender tabs supposed to go... you know, the things that idiots jack up the car on.
My driver's side fender, which bulges out, hangs straight down... meaning the bolts are parallel with the ground.
My passenger fender, which is perfect, looks like the bolts go perpendicular to the ground...
Are the drivers side and passenger side different?
Old Mar 10, 2008 | 07:23 AM
jhatler2002's Avatar
The tabs should be straight up and down and the bolts should be parallel to the ground just like your driver side's fender. Because when they put the jack under them and lift up on the car, thats when the tabs bend from one side or the other. Hope this helps.
