Buffing new paint...help!
So how exactly do i buff new paint? Does it need to cure before I do anything? How long do I have to wait? Also can I use my Porter Cable to do it? What pads and compounds? What settings work best? A step by step process would do me good, starting from wet sanding the clear.
now with wet sanding start with 1500 and get a good block there usually a sponge like material. have a bucket and a spray bottle with soapy water and use alot, so the paper doesnt gum up. Also be very carefull near edges you dont want to burn through and that is were it normaly happens
as you are sanding use, a squeege, a sponge, air or something to dry as you go, once you cant see any more shiny(low spots) switch to higher grits. 2500 will be good, it will make the compounding easier.
i would then wash the truck to get all the loose stuff off.
I used a 3m rubbing compound and a medium cut foam pad. a pc will be a good choice. i wont get to into compounding but i have a link from when i did my truck, it wasnt a new paint job but similar idea. http://www.performancetrucks.net/for...d.php?t=412697mean z71 at bottom of first page has a great link!
then follow it up with perfect-itIII to polish with a fine foam pad.
You should wait 90 days before waxing and that should do it!
Research alot, there is alot to learn, i had to do my truck twice to get the compounding right
oh and make sure you have alot of time set aside and good luck!
The only reason he's wetsanding is to remove orange peel, trash, and tape lines(at least that's my assumption). So no, you definately don't have to do that before waxing.
i havent tried the da sander but have wanted to, there are a few body shops by my cabinet shop and they all us the da's, again just watch out for the edges, ive seen some will tape the edges and go back and hand sand them just to be safe!
STAY OFF THE EDGES!!!! OR A REDO WILL SUCK ***!
reason i ask is i just got my car back with a new ram air hood that was painted as well as my roof...
I just had my whole car repainted, and was told to wait a MINIMUM of 10 days before using any soap and 30 days (90 recommended) before waxing.
Dupont 1500S compound in two steps
- 1st step was with a medium waffle pad
- 2nd step was with a fine pad
Final step was with 3m Ultra Fina with a flat fine pad. Paint is incredible
If you wet sand it you cannot "wax" it, I mean you can but you have to have buffing compound and buff it out to get the shine back then wax it....
So anyway tell me if I have this right:
1) wet sand with 1500 to get rid of orange peel
2) wet sand with 2000
3) wet sand with 2500
4) Use the Porter Cable with compounds and pads to bring the shine back
What pads and compound do I use? When does this "hookit" come into play? A numbered writeup like above would help tons!
alright porksoda if you have a dual action sander and want to use that for the wet sanding, it should have a hook and loop pad on it then you need the sanding pads with the hook and loop backing.
1-3) look good you need to decide to do it by hand or with a DA, DA is faster but can burn through real fast if your not very carefull
4)rinse the truck to remove any contaminants
5)use porter cable and a medium cut pad with a rubbing compound, i used the 3m that you can buy at any automotive store
6) rinse the truck again to remove any compound left over
7)polish with fine buff pad on Porter Cable
and that should be it, wait about a month then wax it
i dont know if you watched this yet but it goes through how to use the PC for compounding and buffinghttp://www.youtube.com/watch?v=GZVDsiEQ8-w
