Got tired of rear panel..
Old Apr 2, 2008 | 10:55 PM
BsGreenZ's Avatar
Default Got tired of rear panel..
I know i'm not the first to do it but i decided to go a different route with my rear facia..Every on started doing the black rear panel so i went with a silver one at first, but then decided since the car is way under the knife i'm going to paint the entre car and decided to change the look of the rear panel.. So I filled in CAMARO and the key hole.. I'll get some pics up soon of the progress but i think it looks 2x better and cleaner..
Old Apr 3, 2008 | 06:36 PM
BsGreenZ's Avatar
Here is some progress pics...
Before:
http://s89.photobucket.com/albums/k2...t=PICT0064.jpg
Almost ready:
http://s89.photobucket.com/albums/k2...t=PICT0070.jpg
Old Apr 3, 2008 | 06:39 PM
jessedale98's Avatar
Need to see some more work, but it looks like your doing it the right way.
Old Apr 3, 2008 | 06:40 PM
BsGreenZ's Avatar
Like???
Old Apr 3, 2008 | 06:41 PM
like smoother, paint. wet sand ect. Or just paint it now and lets have a look. Either way get it done.
Old Apr 3, 2008 | 06:43 PM
BsGreenZ's Avatar
Ok, i'm all over that, right now it was last sended with 60 grit so it looks rough lol..But thanks man..
Old Apr 3, 2008 | 06:47 PM
yea I think when I did mine I ended the wet sand with 2000 grit.
Old May 11, 2008 | 11:54 AM
BsGreenZ's Avatar
Ok so its been a while since i updated this one but i've been busy with finals at tech so here os some more progress, rear panel is just waiting for paint, and i'm actually molding the body kit to the car so there is no gap...
http://s89.photobucket.com/albums/k2...t=PICT0108.jpg
Old May 11, 2008 | 12:53 PM
wannafbody's Avatar
you need to progressively work your way up to 2000 grit.
Old May 11, 2008 | 01:10 PM
BsGreenZ's Avatar
I know, but since i'm about half way done with the rear bumper im waiting to sand them at the same time since it's going to make a mess lol..
Old May 11, 2008 | 04:18 PM
98trans am's Avatar
i'm not an auto body pro, but i think 2000 is way overkill for before paint prep. unless you're talking about wetsanding the clear.
Old May 11, 2008 | 04:33 PM
torquejunky's Avatar
Yeah 2000 is what you sand up to on clear prior to buffing, before primer you want to get up to 220 and before base wet sand with 600, with a soft block. On wholesale (non-metallic base) cars I've done 180 prior to primer then used high build 2K primer then just DA everything with a soft pad and 320 prior to base, but that's just to get them in and out.
Old May 11, 2008 | 04:40 PM
BsGreenZ's Avatar
So far i'm getting every thing with 320 before primer...
Old May 11, 2008 | 05:32 PM
Fast_94_Z's Avatar
2000 before base is overkill. i usually do 220 with a hard block 400 with a hard block600 with a soft block or on show cars with a hard block and on lighter colors and show cars 800 before base. with clear i use 1500 on knibs followed by 3000.
Old May 13, 2008 | 12:14 AM
Sunset'01Z's Avatar
panel looks clean, but i think it needs something there. idk, maybe i just need to see the finished project.
Old May 13, 2008 | 02:37 AM
98RedBird's Avatar
Looks good man. Still some work to be done but looks good. I've seen that clean panel before and really like it.
