Berger Panel Feels rough after paint
Old Apr 29, 2008 | 06:43 PM
xxcoolrollinxx's Avatar
Default Berger Panel Feels rough after paint
just got done doing my panel and it feels rough .. i think its my primer .. should i wet sand ?
if so what grit ? .. prolly high like 1500 right ? .. i want it smooth
Old Apr 29, 2008 | 07:01 PM
joker machine's Avatar
If you think it is the primer you will have to sand it alway down. Then primer,wet sand it 800-1500 paint it again.
Old Apr 29, 2008 | 07:22 PM
torquejunky's Avatar
Did you sand your primer before you sprayed it black and are you using clear?
You could try wet sanding (w/1500) and buffing but if it is the primer you will have to take it back down and get it smooth, then wet sand with 600 and shoot it again. I would not recommend sanding with anything finer than 600 prior to base as you may have adhesion issues.
Old Apr 29, 2008 | 08:01 PM
i did not sand my primer
didnt have any paper
ill try wetsanding and buffing thanks
Old Apr 29, 2008 | 10:30 PM
lmt0705's Avatar
you should always wet sand your primer before painting or you should have used a sealer, it goes on much smoother and leaves a better surface for your base coat
Old Apr 30, 2008 | 08:19 AM
Flamin' bird's Avatar
What he said ^....and also wet sand your clear coat at least in between coats.
