how to align doors?
Old May 3, 2008 | 10:04 PM
beast69camaro's Avatar
Default how to align doors?
Specifically, I need to bring the rear of the door up so it engages properly with the striker (ie. as if the door is sagging). The door is not actually sagging, I just need to realign it after removing the lower hinge because I replaced the detent roller thing. The hinges are good, and I never loosened the top hinge from the chassis.
My questions are (after an unsuccessful search):
- is there a writeup on this issue somewhere?
- what sort of tricks/methods are you guys using?
I know what needs to be adjusted and why (the lower hinge side that bolts to the chassis - it should adjust the door level), but the damn thing refuses to cooperate. It seems no matter how far I adjust it, I can't get the rear of the door high enough and it hits the rocker panel. I guess I'm hoping someone has a clever trick or method they've used in a similar situation.
Old May 3, 2008 | 10:14 PM
95GreenZ28's Avatar
So the door doesnt look misaligned? If not just realign your striker bolt
Old May 3, 2008 | 10:24 PM
It is way misaligned, to the point that it hits the rocker panel. With the lower hinge bolts loose, I can pick up the rear of the door and it will close. I just can't seem to get the lower hinge to stay in that position while I open the door to tighten bolts. Make sense? Just wondering if someone invented a clever technique to do this.....it's kicking my ***.
Old May 3, 2008 | 10:44 PM
95GreenZ28's Avatar
Oh I gotcha. What I did was loosne the bolts and put a 2x4 on my jack and jacked it up where it was closing correctly then bolted it up that way. Had to tweak it a time or 2 though
Old May 4, 2008 | 10:07 PM
Thanks for the reply.
I had been using a cherry picker w/ a padded lifting strap, thinking it would accomplish the same thing. But no luck.
I got out there today w/ my jack and some wood and it worked like a charm. Who'da thunk. Body work still sucks though.
