please help with clear!!!!
Old May 14, 2008 | 02:31 PM
shaun's Avatar
Unhappy please help with clear!!!!
hey guys i need your help!
im painting a few parts on the car and i ran in to a problem with the clear.
im useing duplicolor spray can paint and clear and after i was done spraying the clear a tiny piece of lint found its way on to the part and it stuck.
can i wet sand the clear coat then reclear it? i want to get that speck of what ever it is out lol. i dident know if i could sand the clear then respray it?
im not saying sand it all the way back down to the color coat just sand it with 2000 grit then reshoot it.thanks guys.
Old May 14, 2008 | 02:56 PM
Beyond Static's Avatar
You can sand the piece of trash out with some 2000 grit and reclear it. That's perfectly fine to do
Old May 14, 2008 | 02:57 PM
Xsta Z 28's Avatar
Yes, as long as the re-shoot of clear occurs within the re-spray window of time on the spray can.
Old May 14, 2008 | 03:40 PM
shaun's Avatar
well i finished spraying the part about this time yesterday so will that be ok?
so it will be ok to sand down the whole part with 2000 then re clear it and it wont look hazy or the sanding traces wont show?.thanks for the fast replys.
Old May 14, 2008 | 06:54 PM
Pheonix's Avatar
If you ever run into this again while the clear is still wet get a piece of tape and fold it into a u shape. Then just touch the very tip of the lint and the tape will pick it right up. Then just throw one more coat of clear.
Old May 15, 2008 | 02:00 AM
shaun's Avatar
thanks for the tips guys. i got it done just sanded with 2000 then recleared and it came out good.
