What can be done about the paint chip problem on this?
Old Oct 9, 2008 | 01:08 PM
candlelit's Avatar
Default What can be done about the paint chip problem on this?
Does fixing this really require resurfacing the whole hood? The rest of the hood looks great.
Old Oct 9, 2008 | 04:14 PM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
You can blend the paint but i would clear the whole hood. If you blend the clear the blend line will show up later on. If you plan on keeping the car i would clear the whole hood then you have no problems.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Oct 9, 2008 | 04:40 PM
Cts-Voodoo's Avatar
yes the whole hood gets resprayed. The color is blended out about 12-18 inches into the existing color, but the clear coat needs to be layed down as a solid even layer, thus the whole hood gets sprayed.
Old Oct 9, 2008 | 06:34 PM
z2fast8's Avatar
what made it pop off like that?
Old Oct 9, 2008 | 11:39 PM
candlelit's Avatar
don't remember how it happened, but while we were doing the motor swap my dad happened to accidentally hit that part of the hood with something.
Old Oct 10, 2008 | 10:08 AM
Cts-Voodoo's Avatar
Originally Posted by badmfkr
? can touch-up paint work on the front of his hood?
I have a simiarl paint chip behind the pass. head light was planning on using some left over paint (after painting fender) applying w/ a small brush?
Thanks
The small chip you can half *** with touch up, but brushed on paint wont ever look as good as a true repair.
Old Oct 10, 2008 | 11:47 AM
dragcamaro's Avatar
black shows EVERYTHING too, youd be WAY better off repainting the whole hood
Old Oct 12, 2008 | 08:02 PM
67RSCamaroVette's Avatar
i'll be the first to say no.. don't repaint the whole hood. here's what you do..
get touch-up paint (tiny amount)
get que-tip.
dab a very small amount of paint over the whole chip, wait 8 hours.. repeat, repeat, repeat, until the paint is ABOVE the level of the rest of the paint.
now wet-sand the chip with a flat object until it's level with the surrounding paint, and buff.. no-one except you will ever notice it again.
Old Oct 12, 2008 | 10:47 PM
Cts-Voodoo's Avatar
get que-tip.
Works great unless the paint is metallic or pearl. In which case you knock the heads off the added material and the color looks flattened in one area. But again, for sold colors, yes painting it on and then polishing it out works great.
