Notices
Parts Classifieds This an archive of the older parts classifieds, please create a new listing in our Marketplace.
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
565ci Chevy Nitrous Motor 4.40s 1/8 6.80s 1/4
Old Oct 28, 2012 | 03:08 PM
fergymoto's Avatar
Arrow 565ci Chevy Nitrous Motor 4.40s 1/8 6.80s 1/4
Category: Engine - Complete Motors
Price: $15000
Part Fits: 93-02 Pontiac Firebird
Location (State): NC
Item Condition: Used
Engine: Big Block
LS Engine?: Non-LS Part
This probably isn't the place to sell this, but might as well post it here. Maybe someone knows someone looking.
TURN KEY PACKAGE WITH TUNE UPS - Great motor for Top Sportsman, Grudge racing, 4.50, 4.70, 4.90 index racing.
Have a new motor coming so this one is being offered up for sale.
565ci Chevy motor has been 4.45 1/8 mile in my 2,530lb Top Sportsman door car. It will go 7.teens on a good track on 1 system, and will go 7.20s easily on a mediocre track in mediocre weather on 1 system. On two systems it should go into the high 6.80s. Has been 6.90 back when the motor had plates and a fogger. I did away with the plates and added a second fogger. This motor will outrun and run with a lot of bigger motors, and has QUALITY parts in it. This is not someone's used up, worn out, burned up junk. It is well maintained, fresh, and ready to go fast.
The engine has new Oliver Max series rods, new CP custom gas ported nitrous pistons, new Ackerly & Childs rings, lifters sent in to Competition Cams and rebuilt, new Comp pro mod type triple valve springs, new Hussey head gaskets, nitrous solenoids gone through, etc.
I am offering the engine turn key. Complete from carburetors to headers, water pump to flexplate. Hook up your ignition coil wire, battery power, crank trigger wire, fuel pump and radiator hoses and it is ready to run.
Buyer will get all the tune up info I have, including tune ups for 4.40s on two systems, 4.80, 4.90 index racing tune ups, etc.
Complete parts list is below.
Shortblock:
-World Products Merlin III - 4 bolt main, ARP main and head studs, decked, o-ringed, line honed, 4.610 bore size, screens in lifter valley
-Callies crankshaft, all standard bearing journals
-New Oliver Max series rods
-New CP custom nitrous pistons, gas ported, .043,.043, 3/16 rings, etc
-New Ackerly & Childs HTD rings
-Clevite main and rod bearings
-Durabond cam bearings
Cylinder Heads/Valvetrain:
-Brodix BB2 Xtra CNC rectangle port cylinder heads
-Victory titanium valves
-Comp triple springs
-Comp titanium retainers
-Comp spring locators
-10* locks
-Jesel shaft rocker system, all stands one tied in unit
-Jesel camshaft belt drive
-Comp camshaft
-Comp solid roller link bar lifters
Intake/Carbs/Nitrous
-Dart ceramic coated tunnel ram intake manifold - port matched to cylinder heads, bungs for annular and 90* foggers
-1st Nitrous system - NOS annular fogger system - annular bungs and nozzles done by Jeff Prock of Applied Nitrous Technology. Consists of Speedtech nitrous solenoids, NOS fuel solenoids, NOS nozzles, stainless hardline
-2nd Nitrous system - NOS Pro Shot soft plume 90* fogger system
-NOS purge - one solenoid purges both systems at all four nitrous solenoids
-Mega Machine nitrous shower head distributes nitrous to all four nitrous solenoids from main feed line
-Two Holley Dominator 1150 carburetors
-Phenolic carb spacers
-Carb studs
-Complete Enderle carburetor linkage system with bellcrank in rear
-Barry Grant 4 port regulator for carbs
-New Magnafuel 4 port regulator for nitrous systems
Ignition system:
-MSD Crank trigger setup
-Mallory Distributor
-Accel plug wires
-Autolite plugs
Other:
-3 stage dry sump oiling system - this motor has NEVER hurt a bearing or had a single lubrication issue! There is never any bearing wear.
-ATI Super Damper
-TCI Flexplate
-Moroso valve covers with T handles
-Moroso 3 vane vacuum pump
-Moroso belt drive for oil and vacuum pumps
-Mezeire electric water pump
-Hitachi style starter (works awesome, spins motor fast)
-Hedman Headers - 2 1/4" primaries, 4" collectors - should fit most door cars
-ARP stainless header studs
Also have two TCI converters available - both work VERY well with this engine. One 9", and one 10".
I am asking 15k or best offer for the engine. Please call 704-773-1313 if interested. If you don't get me, just leave a voice mail with your name and number and I will get back to you. Thanks!
Please note: I can ship the engine if desired. Also, I can not include the motor plate as I will need it for my new engine. I am located near Charlotte, NC, but travel to PA and Ohio often and could make arrangements with a possible buyer from the area.
Old Nov 7, 2012 | 08:24 AM
fergymoto's Avatar
Bump bump tell your friends
Old Nov 13, 2012 | 07:03 AM
fergymoto's Avatar
Sold!
