Black 17's w/ Tires(GTO), Focal Speakers, JL Audio 5 channel Amp, Eclipse Amps
Category: Accessories
Price: $200
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, 04-06 Pontiac GTO
Location (State): TX
Item Condition: Used
LS Engine?: Fits LS Engine
Ive got about 20K miles on the tires and there Riken Raptors in 245/45/17's.
Asking SOLD
![](http://i1193.photobucket.com/albums/aa358/NASTY-TA/Mav%20Man%20CF/55B58374-0D29-4390-9FAA-0D6C87C105C0-3679-0000018E5E1FF9D2.jpg)
scuff on bottom wheel flat face.
![](http://i1193.photobucket.com/albums/aa358/NASTY-TA/Mav%20Man%20CF/36AEBE6A-2275-4668-9240-D600E57F8375-3679-0000018E75FA2383.jpg)
Curbing on other
![](http://i1193.photobucket.com/albums/aa358/NASTY-TA/Mav%20Man%20CF/23852A4F-986B-4BA1-BDB6-38AB3AAC6C65-3679-0000018E70D7E4E0.jpg)
![](http://i1193.photobucket.com/albums/aa358/NASTY-TA/Mav%20Man%20CF/9CBF883A-884C-4EF3-B6BC-EC85CE9ADFC7-3679-0000018E7913B761.jpg)
JL Audio 500/5 5 Channel Amplifier.
Specifications:
Front Channels: 100W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
Rear Channels: 25W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
Subwoofer Channel: 250W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
THD at Rated Power: <0.03% @ 4 ohm (F&R), <0.05% @ 4 ohm (Sub)
S/N Ratio* (F&R): >108.5 dB below rated power
S/N Ratio* (Sub): >95 dB below rated power
Frequency Response (front and rear): 5 Hz-30 KHz (+0, -1dB)
Frequency Response (sub channel): 5 Hz-500 Hz (+0, -1dB)
Damping Factor (front and rear): >200 @ 4 ohm/50 Hz
Damping Factor (sub channel): >500 @ 4 ohm/50 Hz
Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions: 19.7"L x 9.25"W x 2.36"H
Features:
Differential-Balanced Input Topology: (3 pairs of inputs)
Front Crossover: Fully-variable (50 Hz-5 KHz), selectable-slope BP or HP (12 or 24 dB per octave)
Rear Crossover: fully-variable (50 Hz-5 KHz), selectable-slope HP (12 or 24 dB per octave)
Sub Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
Preamp Output: 2-channel (full-range or LP)
Bass EQ: Variable boost up to 15dB. Remote bass boost control optional.
Infrasonic Filter: defeatable 24dB/octave at 30 Hz
Left minus Right Ambience Circuit: ambient effect for rear channels
Front and rear speaker output connections: accept up to 8ga. wire
Dual mono subwoofer output connections: accept up to 8ga. wire
+12V and Ground connections: accept up to 4ga. Wire
ASKING SOLD
![](http://i1193.photobucket.com/albums/aa358/NASTY-TA/Mav%20Man%20CF/F6153DAB-4A36-4C72-AFEB-4BD9B41606D7-3679-0000018E8E1B1415.jpg)
Focal Access 130 A1 Component speaker system
includes two 5-1/4" woofers, 2 tweeters, 2 external crossovers, and 2 woofer grilles
humidity-resistant, woven glass-fiber woofer in non-resonant ABS/fiberglass basket
butyl rubber surround
1" aluminum inverted dome tweeter
external crossover with 3-position tweeter level
4-ohm impedance
6-50 watts RMS power range (100 watts peak)
frequency response: 65-20,000 Hz
sensitivity: 91 dB
mounting depth: 2-3/16"
Box still sealed.
ASKING $160 OBO
![](http://i1193.photobucket.com/albums/aa358/NASTY-TA/Mav%20Man%20CF/B2C3E6FB-2347-42A6-BBD8-4018E5AAE3C9-3679-0000018EA2D56079.jpg)
Focal Access 165 CA1
2-way 6-3/4" speakers (pair)
4-ohm impedance
2-60 watts RMS power range (120 watts peak)
frequency response: 60-20,000 Hz
sensitivity: 92 dB
depth: 2-9/16"
ASKING SOLD
![](http://i1193.photobucket.com/albums/aa358/NASTY-TA/Mav%20Man%20CF/B917F53C-D9AC-4955-B147-C5B6DC2F095A-3679-0000018E9B21D25D.jpg)
Old School Eclipse Amplifiers
Eclipse 33230 130x2 Channel Amplifier
310W x 2 Channel Max. Power Output at 2 ohms
200W x 2 Channel 0.1% THD at 2 ohms Stereo, 20,000Hz at 13.8V (RMS Continuous Power)
130W x 2 Channel 0.1% THD at 4 ohms Stereo, 20-20,000Hz at 13.8V (RMS Continuous Power)
ChannelFlex Crossover Adjustable Low-Pass Crossover (12dB/octave, 50-200Hz)
Subsonic Filter (10Hz Fix)
Free-Flow Signal Circuit
Double-Sided PCB
High-Current, High-Speed Output Devices
High-Efficiency, High-Energy MOS-FET Power Supply
Audiophile Grade Component Selection
Intelligent 7-Way Discrete Protection Circuitry
Music Reproduction with Low Distortion & Ultra-Low Negative Feedback
Efficient Cooling with Low-Profile Heatsink
Multi-Mode Configuration
Stereo/Mono Switch
ASKING $100 OBO
![](http://i1193.photobucket.com/albums/aa358/NASTY-TA/Mav%20Man%20CF/D9ADA9C2-3F35-42F3-A84B-05DD77888614-3679-0000018EA55C1DEB.jpg)
Eclipse 32440 Premium 4-Channel Amplifier 85x4
- 200W x 4 Channel Max. Power Output at 2 Ohm Stereo
- 120W x 4 Channel 0.1% THD at 2ohm, 20-20,000Hz@13.8V (RMS Continuous Power)
- 85W x 4 Channel 0.1% THD at 4ohm, 20-20,000Hz@13.8V (RMS Continuous Power)
- 4 x 20A Fuses
- ChannelFlex Crossover
- Adjustable High-Pass Crossover (12dB/octave, 50 - 200Hz) for Front & 120Hz (Fix) for Rear Independently
- Adjustable Low-Pass Crossover (12dB/octave, 50 - 200Hz)
- Free-Flow Signal Circuit
- Double-Sided PCB
- High-Current, High-Speed Output Devices
- High-Efficiency, High-Energy MOSFET Power Supply
- Audiophile Grade Component Selection
- Intelligent 7-Way Discrete Protection Circuitry
- Music Reproduction with Low Distortion & Ultra-Low Negative Feedback
- Efficient Cooling with Low-Profile Heatsink
- Multi-Mode Configuration
- Stereo/Mono Switch
- 2 Stable Design
Asking $100 OBO
![](http://i1193.photobucket.com/albums/aa358/NASTY-TA/Mav%20Man%20CF/0D9E21F8-7EAD-436C-826F-177715C23114-3679-0000018EAF288755.jpg)
Tsunami 1.2 Farad Cap
It works fine, but does have a small dent on it seen in the pic.
Asking $35
![](http://i1193.photobucket.com/albums/aa358/NASTY-TA/Mav%20Man%20CF/E174F6E7-BB94-4525-86DF-0BB2A9F9C56B-3679-0000018EB9EF3AB7.jpg)
If you have any questions or need anymore info or Pic's shoot me a PM.
I prefer Paypal.
Thanks
Kyle
