Notices
WTB Everything For T-56 Conversion
Old Feb 7, 2008 | 06:53 PM
Black99T\A's Avatar
Bump.
Old Feb 7, 2008 | 08:55 PM
Black99T\A's Avatar
Up Top
Old Feb 7, 2008 | 11:40 PM
Black99T\A's Avatar
Back to the top ^^^^^^^^^^^^^^^^^
Old Feb 8, 2008 | 06:22 PM
Black99T\A's Avatar
Bump Bump Bump. I need a Complete Pedal assembly with all the switches and Clips.
and I need All the Hydrolics.
Need Clutch and PP
Old Feb 9, 2008 | 12:03 AM
Black99T\A's Avatar
back to the top
Old Feb 9, 2008 | 11:55 AM
BonzoHansen's Avatar
Pedals $125 shipped. What else do you need?
Old Feb 10, 2008 | 04:33 PM
Black99T\A's Avatar
Anybody Got the U Bolt and Nuts For the master cylinder???????????
Thanks Guys
Old Feb 10, 2008 | 06:44 PM
jwindbigler's Avatar
Thanks Guys
Yup, I have everything that you need. Give me a list, and I will give you a price. I still have the transmission, the Ubolt, and nuts for the master cylinder. I have all the mounts, the petals, the hydraulic lines, ect. Let me know what you need.
Justin
Old Feb 12, 2008 | 01:01 AM
Black99T\A's Avatar
Bump for a Master Cylinder U Bolt and the nuts that go with it.
Does anyone know If I will need a T56 Exhaust Mount or will the A4 Exhast Mount work on a t56? If the A4 mount wont work I also need a T56 Exhaust Mount.
Thanks
Old Feb 12, 2008 | 01:11 AM
Black99T\A's Avatar
Default Here are the parts I have so far.
Shifter
Lower Shift Boot
6-speed console
Clutch disc, Pressure Plate and Flywheel
T56 Crossmember
Torque arm mount
01-02 Master Cylinder
Old Feb 12, 2008 | 09:07 AM
Shifter
Lower Shift Boot
6-speed console
T56 Crossmember
Torque arm mount
Do you even have the trans yet??
Old Feb 12, 2008 | 10:21 PM
  #32
Black99T\A's Avatar
no im going to wait and buy one after i get everything else i need, I want to make sure I have every part for the swap,down to every nut and bolt, then im going to buy a tranny and bellhousing right before i do the swap. I may shop around for a while on that wanna try and get a good one for a decent price
Old Feb 13, 2008 | 07:59 AM
  #33
Im pretty sure that I have everything that you need for the swap. My trans has 27K on it. I want $2K for the trans, and I will hook you up with some of the other parts that you need. I still have everything from the clutch petal to the clutch itself. So if you need anything, let me know.
Old Feb 15, 2008 | 02:28 AM
  #34
Black99T\A's Avatar
Bump for Master Cylinder U Bolt And Nuts,
T-56 Exhaust Mount
Thanks to everyone who has replied
Old Feb 15, 2008 | 09:06 AM
  #35
T-56 Exhaust Mount
I have both of those. I'll sell it to ya for $80 including shipping.
Old Feb 16, 2008 | 05:47 PM
  #36
Cman's Avatar
I have a pedal assy with switched, a MC (u-bolt too). This from an '02. Let me know if you still need these.
Steve
Old Feb 17, 2008 | 01:41 AM
  #37
Black99T\A's Avatar
Ok updating parts list.
The parts I have are
-Shifter
-all the boots
-6-speed console
-Flywheel, Clutch disc and PP
-t56 crossmember
-t56 torque arm mount
-Master Cylinder (01,02) style
Parts I still need are.
-t56 Exhaust Mount (bolts to trans to support stock y-pipe)
-Pedals (with switches and rod clips)
-Slave
-torque arm mount (BOLTS) just need the bolts, I dont know if the bolts from the A4 mount will work?
-inspection cover
-Clutch alignment tool
Thanks
Old Feb 19, 2008 | 01:14 AM
  #38
Black99T\A's Avatar
-Slave
-inspection cover
Thanks
Bump Bump
Old Feb 20, 2008 | 06:34 PM
  #39
Tiresmokin's Avatar
I have a complete pedal assembly, Hydraulic slave cylinder and braided hose, clutch fork and I think that is it.
