Programming and MAF issue with check engine light question. *DELETED*
Old Sep 12, 2003 | 12:52 PM
minty's Avatar
Default Programming and MAF issue with check engine light question. *DELETED*
Post deleted by minty
Old Sep 12, 2003 | 01:56 PM
JeremyF's Avatar
LS1TECH Sponsor
Default Re: Programming and MAF issue with check engine light question.
What year and vehicle do you have? If it is not the oem MAF that came with you year model vehicle then the maf tables are more than likely different. Need more info.
Jeremy
Old Sep 14, 2003 | 08:57 PM
minty's Avatar
Turns out the stock connnector piece that goes to the maf has NO voltage....Either wire is cut somewhere or computer is damaged....
