My 1st experience w/SD tuning.
Here is an example of a stock VE table pulled from a 2002 LS1 Commodore.
And now a tuned VE from the same car running full time SD.. It might not look like much on a monitor but believe me.. The difference is huge.
I live in new England where year round there is about a 100 degree swing between the hottest and coldest days in a given year. I want the tune to be spot on no matter what time of the year it is. Hell if I wanted to constantly be adjusting the tune. I'de throw away all this EFI crap and go carb.
a PROPERLY tuned SD tune is the most accurate and consistant way to tune a car. if you think about it, the maf is a weak link. i've taken a few efi tuning courses and have become quite comfortable with a mafless tune.
the AIT sensor placement becomes much more critcal now.
So you can't just remove/fail the maf, you also have to disable 3 maf codes to avoid getting the full line-pressure mode. That's the only tie-in with the auto tranny that I can think of.
In general, SD can account for air temps. The trick is to get the IAT / ECT blending table set up right. Too little emphasis on IAT and it doesn't adequately cover the change in air density. Too much emphasis on IAT and it over-corrects. This is one I'm still figuring out...
Basic article on Mass Flow vs Speed Density for those wondering
So if you're SD, then the trans is fine as long as your VE is good and not under.
As Macca said, you will be fine... especially the F-bodies (in the US) since thier VE table is close from the factory.
As Jonh_D said, you have to disable the trans failsafes for the 3 MAF DTC's.
