Throttle response?
Old Oct 14, 2008 | 09:22 AM
Rays C5's Avatar
Default Throttle response?
I have a 98 c5(drtive by wire) that pulls well and runs well but throttle response is'nt as responsive as I believe it should be. Is this a "98 " thing pcm wise or are there other areas I can look at to correct this? If so what areas should I address?
Old Oct 14, 2008 | 09:50 AM
Gh0st's Avatar
Jedi Master
What's your timing like in your cruise cells? Stock or did you actually change it as you should with a cam?
Old Oct 14, 2008 | 06:51 PM
Rays C5's Avatar
Idle at 28 and progressively top out at 35. At wot 27.
