Question about anti theft system
Old Oct 22, 2008 | 01:23 PM
samh_08's Avatar
Default Question about anti theft system
I will be swapping a LQ4 from a 05 chevy into my 86 monte carlo and I was wondering if it is possible to disable the theft system and how I should go about doing that. I will not have a BCM or do not have the key that went with it, so using a remote start bypass is out of the question. I have a tech 2 at the college I go to so that would be the easiest method for me if that is even possible. Please let me know. Thanks
Old Oct 22, 2008 | 08:17 PM
poconojoe's Avatar
Most of the tuning software will do it, The Tech2 will not, unless you can find a stock file that would run your motor, that came without the VATS enabled
Old Oct 22, 2008 | 08:27 PM
samh_08's Avatar
Are you sure they can disable passlock 2? that is what the 2005 chevy trucks came with.
Old Oct 24, 2008 | 03:43 PM
samh_08's Avatar
Bump for answer on passlock 2 and my post above. Thanks
