Update on my MAFT adjustments
For right now I'm jsut focusing on the Base tune.
It was set at 0 and the average for the LTFTs are:
LTFT1: 3.75
LTFT2: 4.63
It was lean, so I adjusted the **** to the 1 position, 5% rich, got in the car, turned it on and started logging again immediately (should I have driven for 20 minutes then logged?):
LTFT1: 0.14
LTFT2: 0.55
0 degrees of knock on both logs.
Is this good or should I turn it one more notch to 10% rich to bring it in the negatives? Or leave well enough alone?
Also, I deleted the data from Fuel Cell 0 as I was only supposed to consider the data from cells 1-19.
Chris
