WOT 2-3 will not shift hits limiter
Old Nov 24, 2008 | 06:53 PM
MUSTANGBRKR02's Avatar
Default WOT 2-3 will not shift hits limiter
I have a 2002 T/A with a 4l80e swap done. I have about 1k miles on it or so. Since the swap i cannot get the 2-3 shift at WOT to shift. It runs all into the limiter. I have put my shift points all up, down, left and right, same with MPH. It still hits the limiter. I checked the transmission speed per the ouput RPMX60(rev.mile) and i am within .3 MPH. Only mods are exhaust, airlid and stall(3400).
File Type: hpl
File Type: hpt
Old Nov 25, 2008 | 04:03 AM
i have it all the way to 32 MPH right now and hit the limiter at 57 MPH. Shift RPM is 5000 it hit the limiter at 6700.
Old Nov 25, 2008 | 05:55 AM
BLK02WS6's Avatar
Had similar issues with a 4L80 swap once and never could get it right before the owner decided to put a manual valve body in it. It would skip right to second gear as soon as the car moved. Wish I could have found out if it was in the tune or something mechanical in the trans doing it. I had put a 4L80 transmission segment into the F-Body tune - is that what you did??
Old Nov 25, 2008 | 10:49 AM
I have HPtuners. 3.23 rear and 24.91 tire(275-35/18). I will try this tonight ^.
Old Nov 25, 2008 | 02:53 PM
i will try this later when the roads clear a bit. I would like it to work the correct way though and shift with RPM/MPH. Not just MPH, but i would settle for that right now. I just wonder if it is tune or transmission related??
