oxygen sensor voltage?
Old Nov 25, 2008 | 07:47 AM
lt170chevelle's Avatar
Default oxygen sensor voltage?
dont know if this is the right place to post this but here goes..at what voltages is the afr roughly at? i have been tuning my car for quite a long time and under wot they jump to 940ish ,but keep in mind this is my setup in my sig. it always has kinda lost power up top but wasnt leaning out. well i got curious and lowered some of my maf tuning to lean it out a little and sure enough it totally woke it up. now back to the question at hand. i am now seeing 850ish on the o2 voltage and am just wondering what this is roughly equating to as in afr? and by the way i am absolutely getting no knock.
Old Nov 25, 2008 | 08:50 AM
SSpdDmon's Avatar
Narrow band O2 sensors can't be trusted for WOT. They are good for identifying stoich (14.7:1), which is usually ~500mV, and that's about it. First and foremost, I recommend investing in a WBO2.
With regards to your question, you could be running 13:1 at 850mV or you could be running 13.5:1. There's no consistency in the numbers, so nobody can tell ya for sure.
edcmat-l1's Avatar
There's no real set equation between A/F ratio and narrow band 02. I've seen 12.5 at .890 and seen it at .940 and everywhere in between.
I've seen cars at 13:1 read over .900
I've seen one car that was 11.9/12:1 and read .850
edcmat-l1's Avatar
My point exactly........
Old Nov 25, 2008 | 12:11 PM
ok i didnt know how accurate they were that far up top. was hoping they were but yeah funds are in the works for a wideband..just trying to get by till the time comes. Thanks guys
