Need help setting shift points
Old Nov 26, 2008 | 01:28 PM
2kta--89formula's Avatar
Default Need help setting shift points
I have efilive and I am trying to dial in my shift points. I want the car to shift at 6400 on the 1-2 and 2-3 shifts. I thought that you were supposed to set the mph low for the WOT shift point and then set the shift rpm to the desired rpm. The car has 3.42 gears, I set my mph for 40 on the 1-2 and 73 on the 2-3. With the settings like that the rpm averages 6200 or so. I bumped up the mph to 43 and 80, the 2-3 is now at 6250-6300, the 1-2 is still 6200-6250. Am I missing something here or do I just need to keep playing with the mph? I realize that it will not always shift at the same rpm but I want to get it as close to 6400 as possible.
Thanks!
Old Nov 26, 2008 | 07:50 PM
joecar's Avatar
Set your RPM's to 5500 for all shifts, and then play with MPH's.
Old Nov 26, 2008 | 11:19 PM
Just curious, but if the RPM is not being met how is the shift being commanded?
