mail order tune, or something on my end.
Old Nov 28, 2008 | 03:40 PM
chetmo's Avatar
Default mail order tune, or something on my end.
mods;
forged 347
patriot stage 2 heads
F14 cam
mail order tune
symptoms;
fouled the plugs once
lack of throttle response
car is open headers, but it acts like there is no cam
no choppy idle.
attached is an hptuners tune file, and a short scan.
File Type: hpt
File Type: hpl
File Type: hpl
Old Nov 28, 2008 | 08:50 PM
shoemike's Avatar
ask yourself how someone could tune your car without driving or logging data from it.
small changes, emissions, CAGS, speedometer, injectors (for the most part)
and a few other things could be altered without consequence,
but things like spark, fueling, and airflow forget it.
your mods need a lot of attention.
Old Nov 28, 2008 | 09:00 PM
chetmo's Avatar
understandable, this is good news for me. We think its just dumping way too much fuel, but hopefully its understandable of why im asking the question. I dont want to drive 3 hours and it be something thats not in the tune.
Old Nov 30, 2008 | 03:30 PM
Frost's Avatar
start by putting an exhaust on the car... there is NO WAY that a PCM can operate in closed loop with open headers. Your O2s can't exactly control fueling if you have them hanging out in fresh air.
Old Nov 30, 2008 | 07:08 PM
chetmo's Avatar
mocking up exhaust as we speak, understandable. these cars suck for building exhaust LOL
Old Nov 30, 2008 | 07:46 PM
Frost's Avatar
As noted above,you will still need the extra in-person tuning to get it driving and pulling as well as it can, but that mail order tune may work for you much better once the full exhaust is on the car.
Good luck.
Old Nov 30, 2008 | 09:23 PM
chetmo's Avatar
i mean would open headers cause very weak throttle response, and act like it has no cam in it?
Old Nov 30, 2008 | 10:14 PM
Slowhawk's Avatar
LS1Tech Sponsor
absolutely.
Old Nov 30, 2008 | 10:39 PM
chetmo's Avatar
so basically with the 02's being so close to fresh air, Its F'ing everything up, and causing it to dump way too much fuel possibly, therefore causing the weak throttle, etc.
Old Dec 1, 2008 | 09:01 PM
chetmo's Avatar
seems I might have a dead coil pack!
Old Dec 1, 2008 | 11:31 PM
greased05's Avatar
yea serious ******* up may have occured w/ all that fresh air wash. your second priority is to fix your tune, once you have exhaust done you will be able to drive in closed loop (part throttle/idle) safely since o2 sensors will trim enough, however if you dont get dyno tuned you may be risking your engine everytime you go WOT
Old Dec 1, 2008 | 11:42 PM
chetmo's Avatar
car has never seen more than 3k-3.5k rpms. we are working on everything at the moment. Thanks for pointing me in the right direction though.
Old Dec 2, 2008 | 12:45 AM
5_02ls1's Avatar
drove my ca about 2 miles open headers to get the exhaust back on after h/c...it ran like crap...welded the y pipe and catback on it and it ran great actually went from too rich to lean....I ordered hp tuners the following day...
Old Dec 2, 2008 | 01:03 AM
chetmo's Avatar
damn guess i better be careful with cutout placement.
Old Dec 3, 2008 | 09:06 AM
BLKHAWK1's Avatar
at least 18in from the o2's
Old Dec 3, 2008 | 09:31 AM
chetmo's Avatar
yep, we are putting it close to the rear, BTW exhaust is on the car and WOW this thing is quiet, runs MUCHO better now as well.
