EFIV5 Pro ?'s
However, take care with TP settings on drive-by-wire vehicles.
If you are at all concerned, the quickest and most reliable way to "stop" any overrides is to turn off the ignition.
However, common sense, being careful and the limits that are built into EFILive bidi controls and the PCM should prevent undesired results.
You can increase and decrease the settings gradually using F7 and F8 hotkeys. It's safer than "typing" in the values.
(Note: F7 does not work in the Idle control panel - it will be fixed in V6.1.6)
Paul
