MAxed out LTrims how to correct?
Need to increase fuel flow so multiply by percentage less than 100% and this will increase fueling (decrease and PCM increases flow as it thinks injectors are smaller). If you tell it you have BIGGER injectors (multiply by a percent greater than 100%) you will REDUCE fueling further- this is NOT the direction you want to go.
Changing the IFR will change your PE values- you'll need to reduce PE values from 1.54. At 1.54 and + 25 LTFTs you're too lean and PCM is adding fuel ( +25 LTFTs)
Multiply your IFR by 90% and give it some time to adjust/learn. Then see what additional adjustments you need for LTFTs i.e. to get to 0-> -7%. At Zero to slightly negative LTFTs they will zero out at WOT.
Are you using a wideband O2 for WOT AFR? You need a wideband for the WOT AFR.
Hope this helps some. Good Luck.
joel
If your MAF is stock then rescale the IFR table. If MAF is NOT stock then you should adjust the MAF table OR get a stock MAF.
joel
I had just a minor leak and mine were in the low 20s. Fixing the leak brought them back down into the single digits where they used to be, then I brought them even closer to 0 by usings Binks meathod (X .95 for the whole IFR table). I did not mess with my PE table though, I wonder if I should have?
