VATS bypass help me!
Old Dec 30, 2008 | 07:30 PM
robster's Avatar
Default VATS bypass help me!
ok, i have no clue as to what to buy and the people at radio shack are tards. i printed out the chart off of shbox and it looks like numbers to me. tested my keys and it is 9.53K. what resistor do i need?
Old Dec 30, 2008 | 09:03 PM
poconojoe's Avatar
Get a pack of 271-1330 these are 4.7K resistors. Put 2 of them is series and put that across your wires. This will give you 9.4K of resistance, which is close enough.
Last edited by poconojoe; Jan 1, 2009 at 12:35 PM. Reason: For some reason I misssed the zero on the end of the part number
Old Dec 31, 2008 | 12:01 PM
robster's Avatar
ok tried that. light just stays on now and no start. maybe they arent in good?
Old Dec 31, 2008 | 12:16 PM
poconojoe's Avatar
Are you sure you read your key correctly?
Old Dec 31, 2008 | 12:44 PM
robster's Avatar
pretty sure. both keys read 9.53k
Old Dec 31, 2008 | 04:33 PM
2001NBMZ28's Avatar
That should work assuming they're at least 5% resistors. What's the resistance of them in series before putting them into the connector?
Old Dec 31, 2008 | 06:19 PM
poconojoe's Avatar
On the older setups using the VATS module, before they incorporated it the BCM, I've never had an issue, as long as it was within 10%
Buy 2 packs of the resistors(they're cheap enough) and measure all of them and pick the 2 that add up closest to the correct value.
Old Jan 1, 2009 | 01:22 AM
robster's Avatar
ok. the keys read 9.53K. i bought 4.7K resistors and used 2. nothing happend. wrong ones?
 Michael S. Palmer
Old Jan 1, 2009 | 09:04 AM
poconojoe's Avatar
Did you put 2 of them in series not in parellel?
what was the total resistence?
Old Jan 1, 2009 | 10:18 AM
Doc's Avatar
Doc
How did you hook it up? IMHO, taking the under the glove box panel off and going to the bcm connector, White with black stripe wire pin 7 with your resistors straight to ground is the most straight fwd method.
That is, for an Fbody.
Is this F or Y?
Old Jan 1, 2009 | 12:03 PM
poconojoe's Avatar
Is this F or Y?
But he has to make sure he disconnects the wire going over to the key of the key will be in parellel and cutting the resistance in half
Old Jan 1, 2009 | 12:18 PM
robster's Avatar
02 camaro. all i did was unplug the vats under the drivers side (white wires wrapped in orange) and shoved the 2 resistors in the plug from the harness
Old Jan 1, 2009 | 12:34 PM
robster's Avatar
ok, heres what i just did. i took and unplugged the connector, put the key in and checked the wires from the key cylinder with the multimeter. i believe i should have gotten the same reading as the key, but i got nothing. does this confirm a broken wire in the column area?
Old Jan 1, 2009 | 12:59 PM
poconojoe's Avatar
What color are the wires on the plug you're checking?
Old Jan 1, 2009 | 01:00 PM
poconojoe's Avatar
Are you sure that isn't for the SIS?
Old Jan 1, 2009 | 01:31 PM
robster's Avatar
purple w/white stripe and white w/black stripe
Old Jan 1, 2009 | 01:55 PM
robster's Avatar
i fixed it. thanks guys
