Tach output need help ASAP!
Old Jan 1, 2009 | 07:02 PM
Pate_2008's Avatar
Default Tach output need help ASAP!
I am hooking up a MSD digital window switch and i need to figure out which is the tach output on the pcm. Ok so it says pin #35 so pin #35 is in the top part of the pcm which is the white wire is this the correct one ? Or is it pin #34 white wire in the bottom part of the PCM ? ? if someone could let me know i would appricate it alot thanks ! !
Old Jan 1, 2009 | 07:17 PM
johnson73801's Avatar
if you dont get an answer before tommorow ill look at a pinout when i go to work.
Old Jan 1, 2009 | 08:57 PM
Pate_2008's Avatar
ok i believe its the top part on the pcm is what i have found but not completely sure .
Old Jan 1, 2009 | 09:08 PM
SSAUTOCHROME's Avatar
Maybe this will help.
https://ls1tech.com/forums/pcm-diagn...g-diagram.html
Old Jan 2, 2009 | 01:32 AM
Pate_2008's Avatar
99 is a different pcm than 98
Old Jan 2, 2009 | 08:46 AM
alright pin 35 white wire of connector 2 is blue.is tach output
