No tach output
Old Jan 5, 2009 | 06:06 PM
ryanvv355's Avatar
Default No tach output
I have checked the wiring for the cam sensor and tach, no problems there. I had a P0343 cam sensor code, I found that I had a broke wire in my harness, I fixed that, it cleared the code but still do not have a tach.
Any ideas?
Old Jan 8, 2009 | 12:08 AM
ryanvv355's Avatar
Any help
Old Jan 8, 2009 | 08:40 PM
schwoch1's Avatar
Do You have 12V and ground at the cam sensor plug?
Do you have continuity between the signal return wire at the cam sensor and the PCM????
Just fixed a truck a couple of days ago that had no tach and cam sensor codes, found a lack of 12 volts at the cam sensor!!!
Mike
Old Jan 8, 2009 | 10:05 PM
ryanvv355's Avatar
I just verified 12vdc at the cam sensor 12v reference, good ground on the low reference and continuity through the signal line to the pcm all checked good. Re-checked 12vdc present at tach, good ground, also continuity from PCM C2 pin 10 to tach, no issues. I am stumped, I think I am going to pull the tach out and bring it into work, put it on my waveform generator and see if I can get it to work.
I noticed the shift light only comes on at 0 with the key in run, engine off. When the key is cycled on it goes to the selected shift point but the light does not come on, so i believe it may be the tach itself. I do not remember if the shift light comes on before every start up.
Old Jan 8, 2009 | 11:20 PM
xpndbl3's Avatar
no the shift light shouldn't come on at startup at least on my autometer tach
Old Jan 8, 2009 | 11:22 PM
ryanvv355's Avatar
Okay, cool thanks appreciate it
Old Jan 11, 2009 | 11:46 AM
ryanvv355's Avatar
HPtuners reads and displays hi to low signals from the cam sensor so I know the cam sensor is working and the wiring is good. The tach line out of the PCM has no signal, I will be replacing the computer I suppose
Old Mar 22, 2010 | 10:12 PM
ls1999ta's Avatar
has anyone figured this out yet...jeez!!! got the same problem!
Old Mar 25, 2010 | 10:56 PM
davev78's Avatar
If this is an engine swap or you are using an aftermarket tach and you are using an 03+ pcm you may need to do a pull up resistor. http://www.lt1swap.com/lsx_tach.htm
My tach did not work until I did this circuit, now works like a champ.
Old May 14, 2010 | 09:25 AM
Dirty Vegas's Avatar
Bringing this one back. I've got P0342 Low Voltage Cam Position Sensor, and no tach. From what I've already learned in this thread, I'll check the wiring for good voltage, but what about the tach!?!?!
