Vats Question
Old Jan 7, 2009 | 08:01 PM
vk4444's Avatar
Default Vats Question
Can you bypass the vats system through pcm using ls1Edit if you can can you explain how. im having troubles car wont start try using a doing the resistor thing and it didnt work. i bought a bypass and it only helps to get the injectors working or should just by a remote start and use this bypass?
Old Jan 7, 2009 | 09:18 PM
poconojoe's Avatar
If its not cranking over, bypassing it in the PCM will not fix it, it will only turn the injectors on, you'd still need o bypass the starter relay
