crazy timing dips
the car is breaking up at hight RPM and the logs show wierd timing dips from like 14 to -2 degrees...there is no knock recorded and no retard as far as i can tell
just for info in the log when it happens the afr is like 10.4:1 ( im leaning it out slowly) and the timing around the dip is 14.5 map reads around 129 kpa. then just ranbomly it shoots to -2 ...any ideas
the log is here
https://ls1tech.com/forums/forced-in...-question.html
