question for those of you with a wideband
Old Oct 4, 2003 | 05:28 PM
Blackbird's Avatar
Default question for those of you with a wideband
when you decelerate in gear does your a/f go rich/lean/stay around 14.7?
mine goes into the 12's when decelerating and I always thought it should be leaning out not richening up.
want to get and idea of what others see.
thanks.
Old Oct 5, 2003 | 03:51 AM
blk~2000~Z28's Avatar
Default Re: question for those of you with a wideband
With the throttle blade closed wouldn't any air stop flowing into the engine? I saw in a post that there is still gas being injected even though the throttle has been released. Just my Opinion though, sorry no info about widebands.
Old Oct 5, 2003 | 12:33 PM
red ws6 99's Avatar
Depends on the situation and injectors, pump, regulator. When I did not have my 50 lb msd injector offsets and sizing dialed in, I would get a huge drop in AFR and then it would go back to 14.7:1, this was under light load. Once I dialed in my injector offsets very little drop.
At wot if you suddenly let off the gas you will get extremely lean say 20:1 (probably worse but thats what my fjo will read too).
Gary
Old Oct 5, 2003 | 12:39 PM
Cal's Avatar
Cal
Yeah I think that's normal, mine does the same thing.
