U7198 Predator Tuning question
Old Jan 19, 2009 | 03:25 PM
memphisTa's Avatar
Default U7198 Predator Tuning question
How do I turn off the rear O2's with the predator?
Old Jan 19, 2009 | 03:42 PM
Mike@Diablosport's Avatar
LS1Tech Sponsor
What revision is on your Predator (top line of the main menu)?
Thanks
Mike
Old Jan 19, 2009 | 04:04 PM
memphisTa's Avatar
Old Jan 19, 2009 | 04:14 PM
memphisTa's Avatar
Mike,
I also need to speak with you about sending the unit in for the latest revision.
Old Jan 19, 2009 | 04:53 PM
LS1Tech Sponsor
2.13 is current for those older tools.
To disable the rear O2s go to the modify tune menu, and go to OBDII/HO2S and set all the codes listed there to off, then press ESC until it asks if you want to install the tune.
Thanks
Mike
Old Jan 19, 2009 | 05:00 PM
memphisTa's Avatar
Mike,
Can my unit download tunes from email or do I need a different unit? Can I datalog?
Old Jan 19, 2009 | 05:08 PM
memphisTa's Avatar
i have obdII EGR
obdII AIR
obdII O2 sensor
Which do I use?
