Cold air tuning
It's supposed to be in the upper 20's or low 30's overnight tonight, so maybe I'll get better data on the low end of the RAF table. Richening it up near idle has helped a lot with the stalling, but the cold temps still give it fits. Even with a warm engine, sometimes it will want to roll up and down past idle.
If you think you have a method to ironing out this issue, please let me know what I need to provide
There is a good idle tuning tutorial on the efilive website.
For {B4307}; my car likes between -.03lbs/min +.03lbs/min average. (RAFIG)
32: 3.44865
68: -0.09329
104: 0.13072
140: 0.16643
176: -0.31839
- I mapped throttle cracker vs. RPM vs. Speed, and some of those values are higher than what's in the calibration. Do I need to alter this table based upon the logged values?
- Same for throttle follower airflow vs. TPS... some of the logged cells are higher than in the calibration. Does mean I need to alter this table?
