Guys with the Predator Programmer
Old Oct 6, 2003 | 01:27 AM
Mac 2002 SS's Avatar
Default Guys with the Predator Programmer
Hey Guys,
This past friday night at richmond dragstrip ,my 02 SS wasn't performing like before. It wouldn't shift out of first gear (A4 ) when I left the line. I scanned the car with my predator and a code came up ( DTC) . What is DTC ? Once I deleted the code ,my car went back to driving normal. thanks for any tips
Old Oct 6, 2003 | 01:31 AM
x phantom x's Avatar
STF veteran / 10 second club
Default Re: Guys with the Predator Programmer
DTC = diagnostic trouble code ... what was the actual DTC number??
Old Oct 6, 2003 | 09:38 AM
i didn't see any numbers. i just saw erase dtc and i did and the car started to drive normal again. i'll scan it again to see if it will give me anything.
Old Oct 6, 2003 | 11:56 AM
When you find the code, go to this website, there is a list of codes here and you can match up yours and find out exactly what the code was for.
http://www.obdii.com/codes.asp
(you need to enter in your email addy for some reason, but then it brings you to a huge code database) ... There are one or two other DTC code centers too, I think LS1info.com might have one, but their site was down.
Old Oct 6, 2003 | 11:32 PM
Ok , the code that came up was PO135 025 Heater Circuit, Bank 1 -Sensor 1 malfunction. So ,I'm thinking it may be my driver side oxygen sensor wire could have gotten burned up by my SLP LT's. I didn't have a chance to check it out today ,but I will get under the car in the morning.
Old Oct 7, 2003 | 12:17 AM
JxxxOxxxE's Avatar
If I remember right, P0135, and P0155 have to do with the O2 sensors not heating up fast enough. Mine do it all the time in the winter. I think the general concensus is that since they are farther from the motor, they take longer to warm. If they are not up to temp within a certain amount of time, then you get the code. It should have had anything to do with shifting though...
Old Oct 7, 2003 | 10:41 AM
