Need Some Help
Old Jan 29, 2009 | 11:20 AM
trod's Avatar
Default Need Some Help
Exhaust smell is strong, kinda toxic. Where do I begin? My a/f at idle is 13.6-14.1 range. Normal acceleration 12.8-13.2 and semi fast not getting to any boost a/f is 14.2-14.6 range. Car bucks at 1600rpm to 2000rpm and normal accel. also. Just dont know what to do where to start. Talked to the shop that tuned it last and was told my o2's r probably bad. The thing is I have no engine codes. Any info please.
Old Jan 29, 2009 | 11:46 AM
YellowToy/A's Avatar
Do you have a wideband? You talk about boost, are you going to use a MAF or a custom OS? If you run WOT at 14.2 to 14.6 you will have problems fast. It should be 12.5 or so under boost.
Old Jan 29, 2009 | 01:05 PM
trod's Avatar
SD tune so no MAF. Have not tried WOT. Yes on wideband-AEM uego.
Old Jan 29, 2009 | 01:12 PM
edcmat-l1's Avatar
Can you post a run log and tune?
Are your injectors scaled properly? 60s can present some tuning problems.
Old Jan 29, 2009 | 02:56 PM
trod's Avatar
No i dont have any sorry
