02s
Old Oct 8, 2003 | 03:05 PM
mike02ss's Avatar
Default 02s
Someone please explain this, with maft set at 10%rich at base and ltrims at 0 at cruise but go to 0 to +2 at wot, 02s read 880-900, but with maft set at 15% rich at base and ltrims at -3 at cruise and 0 at wot 02s read 900-920. Tuned back and forth over a 2 week period with same results, I thought 02s would read higher when ltrims do not go to 0 at wot.
Old Oct 8, 2003 | 11:55 PM
Colonel's Avatar
Default Re: 02s
That makes sense. Your WOT mixture is effected by your base settings. If you richen up the base your WOT will be richened as well.
I'd leave it +15% to keep the Ltrims slightly negative and I'd back the WOT trim down to get the O2s where you want them.
Old Oct 9, 2003 | 03:21 PM
mike02ss's Avatar
Default Re: 02s
Thanks Colonel, I thought when you adjusted base it only affected part throttle, but now I understand. Thanks..
