diablosport with NO2
Old Feb 7, 2009 | 07:15 PM
kibZ28's Avatar
Default diablosport with NO2
have an 02z28 slp flowpack, slp maf, 80mmTB, slp underdrive pulley and flowmaster cat back and now the diablosport was wondering if any one has experince useing the tuner with nitrous and do you have to set the factory tune back or can u run it with just retarding the timing i'm new to the ls1 have been an older motor person. i think it should b alright with the tune and backing it down but i just want to make sure because the manual says not to run spray
Old Feb 7, 2009 | 07:27 PM
108dragon's Avatar
Thats a question you probably should direct to Diablosport's techs. If the manual says not to run spray, there is probably a reason. At the very least, they won't take any responsibility for your engine grenading if you choose to run the nos against recommendations. That would be a very costly lesson.
My only recommendation to you is to download Diablosport's PC interface program. Then save a backup of your stock and performance tunes to the PC.
