Turning on Fans with LS1 Edit
Old Oct 11, 2003 | 12:28 AM
BlownChevy's Avatar
blownerator
Default Turning on Fans with LS1 Edit
I would like to make my first edit mission to be turing on my aftermarket e-fans with edit.....I need to find the wire in the harness? PCM?
Any help will be great!
Old Oct 11, 2003 | 11:56 AM
WicketMike's Avatar
Default Re: Turning on Fans with LS1 Edit
if you have a 160stat and ls1edit you should set your fans for 185/180 180/175
Old Oct 11, 2003 | 01:40 PM
XLR8NSS's Avatar
Adkoonerstrator
Do a search in the truck section. You know you're not allowed to post outside of that section. :p
Seriously though, there is a post in there somewhere with the pin # and what you need to do. John @ Speartech can help you out with this also.
Old Oct 11, 2003 | 01:51 PM
BlownChevy's Avatar
blownerator
Thanks...I will stay in my cage from now on.
Old Oct 11, 2003 | 08:07 PM
L-EATER's Avatar
11 Second Truck Club
Pin number 42 on the blue connector. Works great-I've had mine hooked up for several months now.
Old Oct 11, 2003 | 10:28 PM
BlownChevy's Avatar
blownerator
Perfect, Thanks!
