LS1edit? Tuning? Advice please...
What is the best way to go about this? Do I buy LS1edit and then have a pro do the tuning for me? If so -- where is the closest, well-known and respected LS1 tuner to Detroit?
Thanks.
The LTs seem to have made you rich, and it wouldn't take much research to figure-out how to adjust that within LS1 Edit. Basically just multiplying the Injector Flow Rate table by a percentage less than 100%, and also, for WOT, multiplying the PE vs RPM table by a percenatge less than 100%. Plus, in the future, you'll definitely need to make adjustments, whether code editing, or more a/f or timing adjustment. Good luck!
