Hanging idle ? any cure for it?
Old Oct 14, 2003 | 08:14 AM
BLKWS6's Avatar
Default Hanging idle ? any cure for it?
Whenever i am coming to a stop and put the clutch in, the revs shoot up to about 1500-2000 and hang there for a few secs then finally will drop back down to normal idle. anybody have any suggestions on how to cure this??
Old Oct 15, 2003 | 12:28 PM
gojo's Avatar
Default Re: Hanging idle ? any cure for it?
What was done to the car before the problem started?
Old Oct 16, 2003 | 11:42 AM
BLKWS6's Avatar
TTT....
been this way.....
Old Oct 16, 2003 | 05:08 PM
TransAmDriver's Avatar
I thought it is suppose to do that so you have good vaccum for the brake booster when comming to a stop. I know if mine didnt do it I would have barely any brakes.
Old Oct 16, 2003 | 06:18 PM
gator's 99TA's Avatar
the idle air control is acting up. check the IAC needle (sensor) or more easily your hole might ahve been drilled out too much in the TB.
Old Oct 17, 2003 | 02:57 PM
BLKWS6's Avatar
Ive got a stock TB that i can put back on that hasnt been drilled yet. i'll try that and cleaing the IAC and see what happens.
