Random "miss" HELP!
Old Mar 4, 2009 | 08:30 PM
racer313g's Avatar
Default Random "miss" HELP!
Trying to diagnose a random miss. Car cuts out for less than a second then all is fine.
1st time: Straight line, 4th gear, 5000 RPM
2nd time: Straight line, 4th gear, 5500 RPM
3rd time: Turning right, 2nd gear, 2000 RPM
Totally random, I can't replicate or make it do it.
Timing tuner, cam, tuned
Car has 58 pounds of fuel pressure, had P0300 "random misfire" code after cam install/tune while idling in my driveway, which I cleared out. Ideas?
Old Mar 5, 2009 | 05:14 AM
WAHUSKER's Avatar
Load 32767 into all your random misfire tables (Engine Diagnostics tab) & see if that helps.
