Msd 6010?
Old Mar 12, 2009 | 04:08 PM
CB99SS's Avatar
Default Msd 6010?
I finally got the car back together with a new blow thru carb setup running on E85. When driving below 2500 rpm it fills like the car is missing. Once you get above 2500 it goes away. Has anyone had this issue? The car runs really strong under boost. Just when cruising below 2500. Could a coil be causing the problem? We've changed the plugs. Weve rejetted the carb still does the same thing. Even Roger at C&S thinks it's in the MSD Box. Thanks for the help.
