12-17% to much fuel.
Old Oct 18, 2003 | 07:41 PM
95LS1TA's Avatar
Default 12-17% to much fuel.
I just got autotap and my car is adding 12-17% fuel to bank#1. What would cause this? The other side stays right around 0. I just switched all the injecters from one side to the other and made no difference. I have a bunch of codes from the swap but are all emission related except for code p1639 not sure exactly what this is, could this be causing the bank#1 problem or is this just another emmision related code. What would cause one side of the motor to be that far off. It is running pretty rough for a stock motor but not that bad. Please help!!!
Old Oct 18, 2003 | 08:32 PM
sbrown99TA's Avatar
Default Re: 12-17% to much fuel.
A tiny exhaust leak on that side or a weak fuel injector, or a misfire. Hope this helps.
