ECM that uses wide band?
Old Mar 14, 2009 | 07:09 PM
Pavetim's Avatar
Default ECM that uses wide band?
I am going to be putting an L92 engine from an 07 escalade in my camaro. I was going to run either hptuners or efi live with innovate wide band kit. But I was wondering if I can get an aftermarket ECM that uses wideband then I can eliminatet he innovate and just use the hptuners/efi live to read my wide band and run it that way right? Also if this is true and i'm pretty sure hptuners does recognize wide band signal, where can I get an aftermarket ECM that uses wide band sensors and that I can possibly use the stock escalade harness? Thanks guys.
Old Mar 17, 2009 | 06:29 PM
N20SS's Avatar
efi live and hp tuners can both read wideband, but both require it to come from a wideband controller. They cannot read the raw data of the sensor.
