how to pull out the pins on the pcm plug
Old Mar 19, 2009 | 10:26 PM
1997ls1s10's Avatar
Default how to pull out the pins on the pcm plug
???? need to more some pins
Old Mar 19, 2009 | 10:31 PM
matty b's Avatar
this is for a gen 3 PCM, the one withe either the red and blue or blue and green connectors. You gotta pull the colored plastic parts off first. If you look on the sides of the colored prtions youl see little retaining tabs. bend those in with a pocket screwdriver and pop em off. As far as removing the pins, theres a plastic tab that holds each pin in place. With the same pocket screwdriver bend the tab back and pull the wire out. Installing a wire is as easy as plugging it in to the hole
Old Mar 19, 2009 | 10:43 PM
Dragman's Avatar
Napa has pins and tool to get apart!
Old Mar 20, 2009 | 10:38 AM
1997ls1s10's Avatar
thank you
