O2 sensor wiring
Old Apr 2, 2009 | 05:51 PM
TheInferno's Avatar
Default O2 sensor wiring
i know that the rear sensors have the 4 wires two are for the heater and the other two are called the high and low signal i know the high is the actual reading, what is the PCM looking for out of the low output from the pcm. i believe the rear sensors have a isolated ground with this wire also.
