dynojet wideband commander problems
Old Apr 4, 2009 | 12:16 AM
pyro719's Avatar
Default dynojet wideband commander problems
I got this used off a board member, and It dosnt work. When I first hooked it up it was reading idle fine, hovering around 14 to 15/1 but would jump to 18/1 and stay there for a couple minutes then go back to hovering around 14 to 15/1. Now it seems to be stuck on 14.5 at idle and wot. Could it just need a ne o2 sensor? My laptop is able to sync to the commander and shows the same readings as the gauge. Any help would be greatly appreciated.
EDIT... It was the 02 sensor, it works fine now.
