some idle issues (log inside) HELP
Old Apr 9, 2009 | 05:53 PM
bad6as's Avatar
Default some idle issues (log inside) HELP
well i have a problem on start up in colder wheather it will go rich i think when ins in open loop. latley on 1st start up it will die like it did in the log and when i restart it i gotta give it a lil gas then it smooths out. also when driving some times the idle will fall when i push the clutch in and go in to neutral. also it likes to fall or dip when im trying to park. this is the only problems i have with the car, just some minor idle things i would like to get rid of.
in the log when i 1st started it it stalled. restarted with a lil help, i let it warm up then i turned the wheel some to watch iac steps, then i was doing some revs, then i turned it off then restarted.
Old Apr 9, 2009 | 11:34 PM
mvvette97's Avatar
PM me your tune and I can help you out. I just went through the same thing on mine.
Old Apr 10, 2009 | 07:42 AM
bad6as's Avatar
my tune
Old Apr 11, 2009 | 01:22 AM
mvvette97's Avatar
I can probably get this pretty good but I will need to start over. What kind of car and year and what are all your mods you have? By the tune you have it should rev pretty high on startup so something is all out of whack.
Old Apr 11, 2009 | 08:05 AM
bad6as's Avatar
fast toys ram air and lid, 85mm maf ported tb, ls6 intake, stock 98 heads, longtubes, ory, 232/234 110+3 xer lobe cam.
its a 98 6 speed
Old Apr 11, 2009 | 05:13 PM
bad6as's Avatar
fyi i tried a new truck pcv valve and i think that might have been my problem, it dosent flow enough air so i put theold ond back in and it starts great. so i guess if i want to use this new valve i need to increase air flow.
Old Apr 11, 2009 | 07:51 PM
mvvette97's Avatar
I tried to look at you log but I can't get it to open right. Are you still running the stock injectors? From how much airflow you are putting to it on startup it makes me think the tune is way too rich. I'm still looking at it though
Old Apr 12, 2009 | 11:13 AM
bad6as's Avatar
no sorry svo green tops. in cold open loop it sits at 13.8-14.1 so what table to i need to change for that? table b3605?
Old Apr 12, 2009 | 12:17 PM
mvvette97's Avatar
I'm gunna put togethor a tune for your car. Who did the current tune you have?
Old Apr 12, 2009 | 12:25 PM
bad6as's Avatar
i local guy, then ive been doing some tweeking.
Old Apr 12, 2009 | 10:19 PM
mvvette97's Avatar
its a 98 6 speed
what brand of MAF are you running? I have a tune for you that I think may work pretty good but I need to know the exact maf you have so I can set the tables.
Old Apr 13, 2009 | 12:00 AM
mvvette97's Avatar
well I redone the tune somewhat close to the specs of mine. Two things will take a little work, the injector flow rates and MAF settings. in the mean time if you want to flash this in and see what it does. I'll do some more searching for some flow rate tables. I have it set a little more than mine since I have the red top 36 pounders. Also depending on what kind of maf you have I may have to do some changing on that. I couldn't use my tables since I have a stock maf. So let me know what kind of maf it is and I will see if I can get it closer.. Here is the tune so far.
File Type: tun
Old Apr 13, 2009 | 12:04 AM
mvvette97's Avatar
one thing I would recommend is selling the large maf and getting a stocker to put back on. Seems the big MAF causes alot of tuning troubles and doesn't really give any gains. I hear the stock maf can support 500 hp with no problems. Just something to think about.
Old Apr 13, 2009 | 09:16 AM
bad6as's Avatar
its a gm 85mm maf. im over 500 on spray
