Split STFTs only in a certain RPM range?
Old Apr 14, 2009 | 01:18 PM
ws6_z28's Avatar
Default Split STFTs only in a certain RPM range?
I'm running in SD with DFCO and PE mode off. I seem to be getting a pretty bad split in the STFTs (diff of 15) but only between 2000-2400 rpm and when tps = 0. It seems most of my log shows a small split (less than 5) when tps = 0 but it largest in this rpm range...then as tps increases the split goes away.
What might cause the split?
Old Apr 14, 2009 | 03:51 PM
joecar's Avatar
Misfire...?
Air leak only during that range...?
Old Apr 22, 2009 | 07:55 AM
ws6_z28's Avatar
bump...
