P0108 and two other o2 sensor codes
Old Apr 20, 2009 | 10:41 AM
Travose21's Avatar
Default P0108 and two other o2 sensor codes
What could cause this to happen and how do i chase down this problem. Let me know please i am confused i was driving down the road and all of a sudden the car started stumbling and then idle real low i pulled over got my hp tuners out and it was reading those codes can someone help me please
Old Apr 23, 2009 | 08:24 AM
NoGo's Avatar
Isn't P0108 a MAP sensor code (high voltage)?
What other codes are you getting.
Your MAP sensor may have died or shorted. Maybe you baked a couple wires together on the back-end of the engine?
Old Jun 4, 2011 | 06:11 PM
SUPERMAN_00TA's Avatar
I am having the same problem! Did you did you find out what your problem was?
Old Jun 5, 2011 | 12:36 PM
XpEdItIoUs's Avatar
That DTC is set if the pcm reads more than 4.9v on the signal return circuit for the MAP sensor for more than 4 sec. You should have low voltage at idle during high vac around 1.0 - 1.5 volts and high voltage 4.0 - 4.9 at WOT (low vac). You need to check for short to voltage, poor connections at MAP sensor, Poor connections at PCM if all is well then replace MAP sensor and have a nice day.
