Reading deleted codes...
Old Apr 21, 2009 | 12:35 AM
runpasthefence's Avatar
Default Reading deleted codes...
This might be a pretty simple/n00bish question, but I'm new to this, couldn't find it in the FAQ, and for some reason 'advanced search' doesn't work on my laptop...
Anyway, I was pulling codes that read lean on both banks and shift and tcc solenoid errors.
I mistakenly deleted the codes thinking I had solved the issues. I'm still having the problems, but my cheap code reader isn't pulling any codes.
What does it take to enable these codes so that I can confirm these issues?
Thanks
Old Apr 21, 2009 | 03:31 PM
salemetro's Avatar
Thanks
I'm not quite sure what you're meaning by "enable" a code. If you are simply scanning trouble codes, and then delete them....they will not come up again until the ECU detects a problem again.
