Coil problem, need help!!
Old Apr 22, 2009 | 04:17 PM
Hashish's Avatar
Default Coil problem, need help!!
I am throwing codes p0351 - p0358 and the car barely idles and is really rough when i drive. This code is for coil X circuit malfunction. Does anyone have any idea where to start looking for the answer? BTW it is a 2001 ls1 with a 98-00 cam in it if that helps. The motor is also freshly rebuilt with less than 10 miles on it.
Old Apr 22, 2009 | 05:04 PM
69LT1Bird's Avatar
go here and follow the procedures, its probably a wiring issue.
p0351 - p0358
Old Apr 22, 2009 | 10:19 PM
Hashish's Avatar
could fuel fouled plugs cause this issue?
Old Apr 23, 2009 | 06:01 AM
69LT1Bird's Avatar
no, the plugs are fouled because the coils are not firing correctly if I was a guessing man.
